Classic Mini Cooper Spi: Osram Led Bulb Upgrade (Help Needed)
11 replies to this topic
#1 Screwdriver
Screwdriver
  • 281 posts
Posted 29 January 2017 - 06:11 PM
Hello All,
Given how relatively strained the Classic Mini electrical system appears (try running the wiper with heating and lighting on), I've been on the hunt to find ways to reduce lighting wattage consumption and improve safety.
Enter OSRAM LEDriving range of led bulb upgrades.
1) First, I upgraded the front turn signals. Any additional bulb replacement (side/ rear) led to rapid flickering, so I replaced only the front bulbs. The result was a brighter, faster indication.
2) Then, I replaced the license plate lamp bulbs. The result was a brighter, warm white effect.
3) Finally, I replaced the rear parking/ brake bulbs with OSRAM's premium P21/5W bulbs. The benefits in braking illumination response time alone make this upgrade worth it  (See Video).
^ This is where I ran into the following issue - one P21/5W LED bulb worked fine but when I installed the 2nd bulb, the higher power brake light didn't illuminate. I swapped LED bulbs to double check there was no defect and noticed that the brake light worked when the original incandescent bulb was reinstalled.
I'm guessing this has to do with the resistance and hope someone more experienced has a suggestion on how to overcome this?
P.S. Forgive the license plates - new ones on their way.
Edited by Screwdriver, 29 January 2017 - 06:12 PM.
#2 minisprint
minisprint
  • 1,036 posts
  • Local Club: GR8 minis
Posted 29 January 2017 - 06:28 PM
Nice jdm mini!?
#3 Screwdriver
Screwdriver
  • 281 posts
Posted 29 January 2017 - 07:04 PM
Yes, its a 96 JDM 35th Edition Spi Cooper.
#4 minisprint
minisprint
  • 1,036 posts
Posted 29 January 2017 - 10:48 PM
Attached File  image.jpg   50.84K   6 downloads
I've got a jdm montecarlo
#5 Screwdriver
Screwdriver
  • 281 posts
Posted 30 January 2017 - 10:03 AM
Lovely car! Factory aircon?
Any thoughts on my braking light issue (#3 above)?
#6 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
  • Local Club: Solihull Mini Classic Club
Posted 30 January 2017 - 10:11 AM
I have got Spydia LED lights in the rear of my Mini.
They are built up to give the same resistance on the circuit, but far less wattage being used!
If you buy them through my website using the discount code you save 5% too!
www.localminichat.co.UK/shop
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 30 January 2017 - 10:42 AM
Is the wiring the correct way around for the LED?
#8 Screwdriver
Screwdriver
  • 281 posts
Posted 30 January 2017 - 12:28 PM
The bulbs 2 protruding connectors were correctly positioned (similar to the incandescent, one was placed more towards the tip than the other). There was no wiring other than this that I'm aware of.
#9 tiger99
tiger99
  • 8,584 posts
Posted 03 February 2017 - 06:05 PM
If they are designed to have the same resistance they draw the same current.
Indicators that flash too fast are illegal. I recommend checking the flash rate carefully. You can get a proper flasher which will worth with LEDs. It needs an earth, usually. It is a good idea to change all bulbs, except headlights and reversing lamp, to LED, not to save current but because they are much more reliable. The reason you can't do the reversing lamp is that the law is an ass. The maximum light output is not specified, e.g, in lumens or other optical units, lie the other lamps. Instead the lamp power was specified as a maximum of 21 watts. As for the headlights, there are compelling technical and legal reasons why it would be a very bad idea on a Mini in the UK.
The Mini electrical system is fully adequate to supply headlights, heater, demist and wiper simultaneously, if properly maintained. It is common to fit an uprated alternator if a replacement becomes necessary, and that gives even more margin. If it is inadequate, check fan belt, cleanliness and integrity of all earths, the type and condition of the battery terminals, cleanliness of the stack of terminals on the solenoid incoming terminal, and lubrication of wiper drive rack.
#10 Screwdriver
Screwdriver
  • 281 posts
Posted 07 February 2017 - 02:58 PM
Many thanks Tiger. I believe I have the uprated alternator because the car has factory aircon.
Any thoughts as to why only one of the LED brake lights are illuminating when both P21/5W led bulbs are installed?
#11 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 07 February 2017 - 11:02 PM
LED globes only work with the polarity around the right way. It's possible the + and - wires are around the wrong way (as normal incandescent globes work either way).
If the issue is on one side of the car and is the same for either LED bulb that may be your issue
#12 Screwdriver
Screwdriver
  • 281 posts
Posted 07 February 2017 - 11:34 PM
I'll give it another go and report back!
