Classic Mini – 998cc with 1275 (12G940) Cylinder Head STAGE 2 – 1047cc
£2,250.00 £1,912.50 £2,295.00 inc. VAT
Includes Surcharge Payment
A-SD have been building A-Series Engines for Road and Race use since the 1970’s, with machinists from the era when tuning the A-Series was for real competition use we know how to get the most out of the engines no matter what your application or needs.
Since the 70’s the most cost effective way to get power into your A-Series powered car was to start with a 1275 / 1300 power unit. This has been turned on its head in recent years, where you can now be spending anywhere upto £500 for an untested 1275 unit.
Our in-house team has been working behind the scenes, coming up with exciting and cost effective ways of getting genuine power and reliability for different applications from the smaller bored A-Series units. With interest from specialists and car enthusiasts, you can be sure you will be seeing the A-SD performance packs on plenty of 998 and 1098 Power Units.
998 Stage 2 Tuned A-Series Engine
Originally developed in 2015, We have been testing this spec in our workshop / staff cars that is used for weekend pleasure rides along with commuting in the better weather. We have been incredibly impressed with the drivability and performance from this product.
Specification
- 998cc, Over-Bored to +0.60 1047cc
- Block refaced, Chemically Cleaned with new core plugs.
- High Compression Pistons
- Reground, Balanced Crankshaft
- Mahle Big End Bearing Shells
- Mahle Main Bearing Shells
- Camalot 4 Performance Road Camshaft
- New iSky Followers
- New Push Rods.
- New Duplex timing chain kit.
- New Water Pump, Oil Pump
- Reconditioned 12G940 Large Valve cylinder head, mild porting, uprated springs.
- Water Temperature Sensor
- Oil Pressure Relief Valve
- Oil Pressure Switch
- New Forged Rockers
- Tailored Electronic Distributor
- 10mm HT Leads
- NGK BPR7ES Spark Plugs
- Powerlite RAC463 Starter Motor
- HIF38 Carburettor
- Ramair Air Induction
- Built up with new, quality hardware throughout. Head studs, Con Rod bolts and all ancillary bolts.
- Payen Gaskets
Built up to the highest quality standards, complete with initial start up papers, warranty papers and set up instructions.
On completion of each build, Our Engines are set up and run on our purpose built test bed. During this initial start up the water temperature and oil pressure are monitored and we inspect to make sure there are no water or oil leaks. With the test complete the Engine Oil is drained and the engine is secured into its crate for shipping or collection.
Giving you the reliability and power of a mildly tuned 1275, with incredible drivability.
These engines are available to order through A-Series Spares, please discuss your specification and requirements.
There are two surcharge payments applied to these engines. If you have a like to like engine to return to us then both of these will be issued back to you.
998cc Surcharge: £150.00
Most customers will have an engine to send back to us, and where possible we encourage this as it means that we always keep a healthy stock of doner engines to
recondition. We ask that the engines are cleaned off and drained of all fluids as our courier can refuse to collect engines that are leaking fluids.
Engine Pallet Surcharge: £50.00
Our workshops have engineered metal frames that secure inside a crate to safely transport the Engines. We are keen to get these back to save our workshop having to recreate them. These are ideal for you to secure your engine to and send back, but if you do not have an engine to send back, simply send the frame back to get your surcharge payment back.
http://shop.aseriess...t-stroke-flier/
Edited by A-Series Spares, 30 January 2017 - 06:55 PM.
