Oil Temperature Gauge Pick Up Point?
4 replies to this topic
#1 Lenhamracer
Lenhamracer
  • 118 posts
Posted 09 February 2017 - 08:37 AM
Hi
I wonder where is the best point to fit an oil temperature sender? I have a mocal inline unit which would fit in between the oil hose but I wonder which side of the oil cooler is better? Or would you buy an adapter for the sump?
Thank you very much
#2 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 09 February 2017 - 08:49 AM
Don't put it in the sump, it's the coolest part of the engine. You need to see it where it's hottest!
#3 nicklouse
  • 18,998 posts
Posted 09 February 2017 - 08:54 AM
well I would be fitting a thermostat in there as well and then fit the temp sender after the stat.
that way you will see the temp of the oil going around the engine.
#4 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 09 February 2017 - 10:02 AM
Dsn do a real nice filter housing with sender, got one for my hybrid a+ MPi build
#5 Swift_General
Swift_General
  • 871 posts
Posted 09 February 2017 - 10:54 AM
Oil filter housing as measures temp after the pump just before the oil reaches the bearings. DSN one is very nice, although Somerford do a kit which is much cheaper, effectively a sandwich plate that sits under the housing, although this can give issues with clearance between the oil filter and subframe.
