Torque Wrench Help
12 replies to this topic
#1 jayh29
jayh29
  • 219 posts
  • Local Club: Box Hill mini group
Posted 09 February 2017 - 11:40 AM
Hi,
Forgive the dumb question...I've had to borrow this wrench and it's completly different to mine, I'm trying to torque up the clutch spring housing@ 22nm where approx should it be set? thank you.
#2 Dusky
Dusky
  • 5,322 posts
Posted 09 February 2017 - 11:44 AM
Nowhere as it's not within the working range of the wrench.
#3 nicklouse
  • 18,999 posts
Posted 09 February 2017 - 11:46 AM
as above not suitable for the job in hand.
#4 jayh29
jayh29
  • 219 posts
Thanks... that probably explains why I was struggling.
#5 MacGyver
MacGyver
  • 1,028 posts
Posted 09 February 2017 - 11:47 AM
If you use this one, you'll break the thread before you here the 'clic'.
You need a lower range torque-wrench as pointed out above.
#6 jayh29
jayh29
  • 219 posts
Posted 09 February 2017 - 11:57 AM
Thank you, (goes off to buy new wrench)
Jay.
#7 nicklouse
  • 18,999 posts
Posted 09 February 2017 - 11:59 AM
Jay.
will not stop there. I have three. covers most things. except VW T4 hub nuts.
#8 MacGyver
MacGyver
  • 1,028 posts
Posted 09 February 2017 - 12:02 PM
Jay.
😂 same here!
#9 nicklouse
  • 18,999 posts
Posted 09 February 2017 - 12:07 PM
it is (in my view) best to be using a torque wrench in the middle of its range rather than the extremes of it range.
calibration and checking is good.
also I always set the wrench and then check it works against a bolt in the vice.
just to check it clicks and get a feel for when it will click.
#10 carbon
carbon
  • 2,590 posts
Posted 09 February 2017 - 05:54 PM
Confession time - I only use a torque wrench for head studs, main caps, and bigend caps.
Everything else done by feel. Has worked fine so far.
#11 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 09 February 2017 - 06:28 PM
22nm is naff all anyway I do my shoe laces tighter
#12 Its a min
Its a min
  • 284 posts
Posted 09 February 2017 - 11:08 PM
I use one of these:
https://www.machinem...uk/p/040215238/ and have these: https://www.machinem...et-adaptor-set/
A bit bulkier than a torque wrench but doesn't need re calibrating...just a new battery and the 4 piece adaptor set means I can use pretty much any ratchet or socket size.
Doesn't go to 22nm though.
#13 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 09 February 2017 - 11:38 PM
Jay.
One is never enough.
