Two Line To Single Brakes
21 replies to this topic
#1 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 13 February 2017 - 06:27 PM
Evening all, I am converting the brakes that are going onto my Classic Hot Rod from dual line to single line. I have a kit to convert the Metro 4 pots to single line and have bought myself a used complete pedal box, in-line servo and tandem master cylinder (the heavy duty job fitted to later cars). My question is - what do I need to do to the master cylinder to make it single line? Just blank an outlet? If so which one? How say you.
                                              Many thanks for reading. Hazel ;D
#2 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 13 February 2017 - 06:48 PM
You'll need a single line master cylinder
Any pics of this hot rod? Sounds cool :-)
#3 absx2
absx2
  • 916 posts
Posted 13 February 2017 - 06:58 PM
Big can of worms coming up  :ohno:
You will probably be voiding your insurance unless the car was manufactured with a single line system and I can`t see why you want to take a giant leap backwards on such a safety critical item as the dual line system is simple enough to fit ?
#4 cal844
cal844
  • 9,625 posts
  • Local Club: TFMOC
Posted 13 February 2017 - 07:00 PM
Sweet, I like classic rods, any pictures of this beast?!!!
#5 nicklouse
  • 18,618 posts
Posted 13 February 2017 - 07:14 PM
What he said.
#6 Scousemouse
Scousemouse
  • 358 posts
Posted 13 February 2017 - 08:35 PM
He's putting them on a HOT-ROD  so NOT STANDARD
#7 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
Posted 13 February 2017 - 10:36 PM
This is going to be used solely on 1/4 mile oval tracks (same as stock cars) So I don`t need a lot of braking and insurance doesn`t come into it. I`ll do a build diary on here when I got a bit more to show. At the moment it is a shell, a partly built front subframe and so many components my head is spinning, lol
Edited by Mini-Hazel-Nut, 13 February 2017 - 10:36 PM.
#8 nicklouse
  • 18,618 posts
Posted 13 February 2017 - 10:57 PM
You will need an adjustable regulator fir the rear brakes. Weather this is one il line to th rear brakes like I have done or an adjustable pedal box with two seperate MCs connected on an adjustable bar to alter force applied is up to you.
All I will say is check your regs. You may need two brake systems/lines. Will a mechanical handbrake count as one?
#9 absx2
absx2
  • 916 posts
Posted 14 February 2017 - 08:47 AM
Ok, got it.  I work with a couple of guys that drive big american pickups and old ford pops with v8`s etc as daily drives and us old boys refer to them as hot rods hence my confusion.
#10 cal844
cal844
  • 9,625 posts
  • Local Club: TFMOC
Posted 14 February 2017 - 11:58 AM
Read the regulations here:: http://www.spedewort...arace/rules.php
Then click on the classic hotrod rules download 2017
#11 nicklouse
  • 18,618 posts
Posted 14 February 2017 - 12:26 PM
interesting. no 4 pot brakes except for Minis that must use the Metro cast 4 pots.
sounds like single line brakes are permitted with no back up.
#12 cal844
cal844
  • 9,625 posts
  • Local Club: TFMOC
Posted 14 February 2017 - 12:42 PM
That's what I read, also that the lotus twin cam engine can be used in minis ;)
EDIT:: SEE NEXT COMMENT!
Edited by cal844, 14 February 2017 - 12:45 PM.
#13 cal844
cal844
  • 9,625 posts
  • Local Club: TFMOC
Posted 14 February 2017 - 12:43 PM
That's what I read, also that the ford 'Kent' push rod engine can be used in minis ;)
#14 nicklouse
  • 18,618 posts
Posted 14 February 2017 - 12:46 PM
only one size of tyre available. even wider than mine.
#15 cal844
cal844
  • 9,625 posts
  • Local Club: TFMOC
Posted 14 February 2017 - 01:02 PM
Yeah about 8 inches width iirc
