Is It Possible To Balance A Flywheel Without The Crank?
11 replies to this topic
#1 ozz1
ozz1
  • 141 posts
Posted 14 February 2017 - 10:41 AM
Is it possible have a flywheel balanced without the crank?
If so, where does this in or near Surrey and what should you pay?
Cheers!
#2 nicklouse
  • 18,685 posts
Posted 14 February 2017 - 11:35 AM
yes it is.
but best to do it all together with damper.
#3 Cooperman
  • 23,325 posts
Posted 14 February 2017 - 11:45 AM
It is pretty pointless if the crankshaft, flywheel, clutch and front pulley are not done as a sub-assembly.
#4 nicklouse
  • 18,685 posts
Posted 14 February 2017 - 11:50 AM
unless it is a verto as they were sold as a balanced set by BL/Rover.
and as we know they can be way out.  better than nothing.
#5 Spider
  • 15,098 posts
Posted 14 February 2017 - 11:59 AM
Yes. If the Crank and other spinning parts are done, there's no reason why it won't come up good too.
#6 ozz1
ozz1
  • 141 posts
Posted 14 February 2017 - 12:20 PM
crankshaft and damper are balanced and its possible the flywheel is too - I never had it checked.
its pre-verto, the flywheel does have two holes drilled that I thought were factory balancing - which I now assume not?
Edited by ozz1, 14 February 2017 - 12:31 PM.
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,766 posts
Posted 14 February 2017 - 12:43 PM
Yes it is and I do it all the time.
AcAttached File  WP_20161102_21_48_36_Pro.jpg   55.93K   22 downloads
Edited by ACDodd, 14 February 2017 - 12:43 PM.
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,766 posts
Posted 14 February 2017 - 12:47 PM
Some are out a long way;
Attached File  WP_20161222_16_06_34_Pro.jpg   61.1K   29 downloads
https://m.youtube.co...h?v=bQWBcCKpeeE
Ac
Edited by ACDodd, 14 February 2017 - 12:55 PM.
#9 ozz1
ozz1
  • 141 posts
Posted 14 February 2017 - 03:24 PM
Your video sums it up really!! will definitely have it checked now
#10 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 14 February 2017 - 03:46 PM
Cheers!
I've used these guys in the past http://cmesuk.com/ just across the other side of the M3 ... not 100% sure but I think they balance too.  Do lots of A series for the inline racing boys.
#11 nicklouse
  • 18,685 posts
Posted 14 February 2017 - 04:39 PM
Cheers!
thinking on- OAP are down your way. he is on here as well.
#12 mini-geek
mini-geek
  • 1,169 posts
Posted 14 February 2017 - 05:17 PM
Mine was balanced on the shops balanced balancing shaft
Lol
