Mini Heater, How Warm Do They Get?
Posted 14 February 2017 - 02:21 PM
Posted 14 February 2017 - 02:50 PM
as hot as the engine.
Posted 14 February 2017 - 02:55 PM
They get bloomin warm.....as Nick says ^^^^ as hot as an engine......which is warm!!!!!
You've probably got an airlock or sludge in the matrix.
Posted 14 February 2017 - 03:00 PM
Don't expect the sort of heat you'd get in a modern car! Flushing out the matrix with a hose is probably going to help.
Posted 14 February 2017 - 03:27 PM
Make sure your coolant level is up and you have a sensible thermostat like 88C for winter.
Posted 14 February 2017 - 03:57 PM
Posted 14 February 2017 - 05:37 PM
Posted 14 February 2017 - 06:08 PM
I have a twin speed one from an MPI. It gets very warm. On the slow setting, even on a cold day, I can't have it on for long as it gets too hot in the car.
Posted 14 February 2017 - 06:11 PM
I've got a replacement all metal matrix, my old one with the plastic bits broke. Also re-assembled the system with new silicon pipes but forgot to put the on/off valve back so coolant is always flowing, I just put the lever into the off position when not needed. Its really toasty though when on, dont need the blower on even on cold days if i need to use the car.
Posted 14 February 2017 - 08:31 PM
Posted 14 February 2017 - 08:49 PM
As well as making sure the coolant circuit through the matrix is clean and free flowing, as many of the other guys have already said, be sure the Fins are clear and not blocked up with Hair and crud from the Carpet. If the Air can't free flow through the Matrix, it's effectively just another pipe and not a heat exchanger.
Many I've stripped down is pretty blocked up in this way.
Posted 15 February 2017 - 08:15 AM
Very toasty as others have said.
No need for the fan either when on the move the ram effect is enough.
Posted 15 February 2017 - 11:57 AM
Takes about 15 minutes for it to really get working (there's a whole lot of cast iron in the engine to heat-soak into) but then it's lovely.
Posted 16 February 2017 - 12:58 PM
The valve itself may fail. Beware, there has been a faulty batch of those which burst under pressure. The really old brass one with the underbonnet lever is known for its reliability, if you can find one.
I have seen suggestions about using a VW Golf valve, but don't know which model of Golf. It fits in line and you would have a simple stub pipe on the head. Only if the existing valve is the problem, of course.
Posted 02 May 2017 - 07:40 PM
In my experience, classic Mini heaters go much hotter than a modern car! However the fan is far weaker than any modern car.
