Bmw K100 8V Or 16V
6 replies to this topic
#1 Morten
Morten
    Starting My Mini Up
  • 2 posts
Posted 16 February 2017 - 11:24 PM
Hi there
I Was thinking, would it be better to go for the BMW k 100 8v instead of the 16v if i would like a torque engine with lots of bottom end power instead of an high reewing screamer. I know the amount of work in the konversion is the same what ever head is used.
Regards Morten
#2 nicklouse
  • 18,684 posts
Posted 17 February 2017 - 12:49 AM
The only reason to go for an 8 valve would be if the 16 would not fit over the bores.
16v with suitable cam profiles.
#3 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 17 February 2017 - 03:58 PM
Here is the rolling road screen shot for my 16v BMW headed 1380
Lots of torque throughout
DA4C4B5C-9FE5-4060-A45E-C1B2D7957AFB_zps
#4 Morten
Morten
    Starting My Mini Up
  • 2 posts
Posted 17 February 2017 - 04:08 PM
Very impressive torque curve and from an relativ low rpm.
Is it HP on the wheels?
Are you running standart BMW k1200 RS head whit BMW trhottle bodies. And how heigh is the compression??
Greetings Morten
#5 mini-geek
mini-geek
  • 1,169 posts
Posted 17 February 2017 - 06:39 PM
Is that an at the wheels figure?
#6 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 17 February 2017 - 07:22 PM
Yip that is at the wheels.
Standard k1100 head and throttle bodies. Let me come back with the compression figure
#7 mini13
mini13
  • 3,811 posts
Posted 19 February 2017 - 10:55 AM
as a comparison, heres a read out from a freinds 8v (totally standard head) 1380, this is a flywheel figure,
