Mini Loosing Power When Goes Through A Puddle.
Posted 22 February 2017 - 05:28 PM
Posted 22 February 2017 - 05:38 PM
Welcome to The Mini Forum, while some of the member do own the BMW variety of mini, this forum is predominantly Classic mini orientated. You might get a faster response from http://www.<span sty...ni2</span>.com/
Posted 22 February 2017 - 05:48 PM
The only thing I can suggest is that you have a look behind the grill and at the front and give any wires a good spray with something like WD40 as it sounds like a connection is getting wet and is effectively reducing electrical input. If it was a classic mini I would suggest spraying the distributor cap, and spark plug leads. You may also want to try posting your problem up on www.mini2.com or www.totalmini.com which are sites for the BMW variant mini as this forum is predominantly for classic mini's. They may have encountered this problem and have a better chance of guiding you to the solution. Good luck.
Posted 22 February 2017 - 07:51 PM
Posted 23 February 2017 - 07:21 PM
On the BINNI the "Brain" or ECU is located in the drivers side wheel well.This is prone to getting wet,only way to fix is either wrap it in a bin bag or sell your BINNI + buy a MINI
