Wheel Alignment After Brake Conversion
#16
Posted 01 March 2017 - 12:23 PM
#17
Posted 01 March 2017 - 12:41 PM
I have always used a standard commercial grade steel washer and a Nyloc nut. never had any problems in over 50 years of doing this.
Use a flat washer, a Nyloc nut, nip it up firmly, but not over-tight, and al will be well.
#18
Posted 01 March 2017 - 08:24 PM
I will fit a new nyloc and plain steel washer on the track ends. I will also check the swivel hubs are torqued correctly.
Thanks to all and will update on my progress
#19
Posted 04 March 2017 - 06:43 PM
#20
Posted 05 March 2017 - 08:27 PM
WD40 is NOT a penetrating oil, it is just a lubricant.
To help free off seized threads a penetrating oil such as 'Plus Gas' is needed. It that doesn't work use a blow torch to get some heat into it.
#21
Posted 06 March 2017 - 12:08 AM
I want to jump in and add to this thread as I'm about to set the steering after rebuilding my entire front suspension on my 78' Mini 1000. I've got the steering wheel set at a "Straight" position. I understand the distances front and back on the front wheels need to be different for proper toe, but how do I set the first wheel to be considered "straight"?
#22
Posted 06 March 2017 - 10:21 AM
Turn both track rods the same distance .. one in, one out ... or take the steering wheel off and reposition.
Or ask the tracking guy to do that (he should anyway!)
#23
Posted 06 March 2017 - 01:52 PM
I was hoping maybe there was a reference point one could use to set the first wheel (eg. X" from reference surface). Then the second wheel could be set with the proper toe. From there it could go to the tracking alignment for final set.
I guess I can set the first wheel measuring equally front & back from the front subframe.
#24
Posted 06 March 2017 - 02:58 PM
You wind the track rods on exactly the same number of turns each side and, using two long straight pieces of timber, set them until the wheels are straight ahead and parallel. This gives a basic setting
Then get the car professionally tracked, making sure the adjustments are done by winding each track rod the same amount, and after that take the steering wheel of and centre it on the splines.
#25
Posted 06 March 2017 - 04:17 PM
Thanks. That makes sense to me. I thought you'd start at the steering wheel but I had it backwards as ending there is certainly easier.
Paul_F
#26
Posted 07 March 2017 - 12:58 PM
You should use the centering facility on the steering rack. On the passenger side toeboard there is a blanking plug. Remove it, and the plug in the rack will be revealed. The design varied over the years but most are metal and just unscrew. I hear that some plastic ones are a push fit. Get a 6mm diameter rod (back end of a drill bit is ok), insert it and rotate the wheel till it locates in place. The rack is now centred.
It has to be centred before setting the tracking, however some people do it by counting turns of the wheel which is less accurate, and may result in slightly unequal turning circles in each direction, and bump steer.
I have heard that on some late models the centering facility was omitted, which is not a good thing. In that case, just do your best with turns of the wheel, or undo the rack gaiters at their inboard ends (oil will spill) and set the wheel for equal clearance between the back of each ball joint and the end of the rack tube.
If you centre the rack at home, and while the pin is in place centre the wheel on its splines, you can then go to the nearest tyre dealers and get them to set the toe on their accurate gauge with the wheel centred, as they may not be familiar with the centering process.
The centering hole must not be used for topping up the rack with oil.
#27
Posted 20 March 2017 - 09:47 PM
