Hi all has anyone got a dummys guide to checking the wheel alignment and toe in / out on mini, looking at mine from the rear it looks like the drivers side wheel is in at the top positive camber , how can I adjust this? I have fitted a new sub frame and everything suspension wise has been refurbished, its only when I fitted the wheels and new tyres that I noticed that's the geometry looks a little out. Thanks in advance .
Rear Sub Frame, Wheel Alignment
Posted 28 February 2017 - 05:33 PM
Posted 28 February 2017 - 05:39 PM
or is that negative camber... anyway some advice would be good. pls
Posted 28 February 2017 - 05:45 PM
In at the top is negative camber.
In the modern digital era the easiest way to measure it is with a straight edge that just reaches rim to rim of the wheel and a spirit level app on your phone
Posted 28 February 2017 - 05:48 PM
Edited by Swift_General, 28 February 2017 - 05:51 PM.
Posted 01 March 2017 - 01:37 PM
Thanks for all your help, I have removed the brackets and with a bit of fettling and adjustment the car now sits a lot better on a flat floor. Thanks again all
