Drilling Hole For Temperature Sender
3 replies to this topic
#1 declfc
declfc
  • 86 posts
  • Local Club: Yeovil
Posted 28 February 2017 - 06:12 PM
Does anyone has experience drilling the hole on the (late type) cylinder heads for the coolant temperature sender.
I've done a good search but I cant seem to find a definitive answer. From what I can gather its a two stepped hole.
The top hole has the thread in it (5/8 UNF) then the bottom hole is for the tip of the temperature sensor to go through
and the temperature sensor seals on the seat between the two holes.
Does anyone have anymore information than this? Depths, dia of bottom hole.
Attached File  Temp1.jpg   80.04K   18 downloads
Attached File  Temp3.jpg   8.55K   0 downloads
#2 Spider
  • 15,684 posts
Posted 28 February 2017 - 08:21 PM
I've done a number of them.
I drill right though first with a drill for bulb part, then drill in deep enough for the seat with a 14.7 mm (or 37/64"). I then finish the seat with a 900 counter sinking bit, then tap at 5/8" UNF..
Tip: Use a drill stand or mill for all operations, including starting the thread off and when drilling with the 14.7 mm drill, use a depth stop to avoid embarrassment.
#3 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 28 February 2017 - 08:24 PM
Hmm, mine was drilled in the traditional position and I recall the machine shop using a single drill for the hole then taping it with a manual tool. I have a capillary gauge so have the extended insert type fixing, which seals perfectly.
#4 slidehammer
slidehammer
  • 1,202 posts
  • Local Club: LSMOC
Posted 28 February 2017 - 08:54 PM
You could always use a sandwich plate between the thermostat housing and the head (pre drilled and tapped for a sender unit). Rather risk messing up your head if you are worried.
