Please Identify This Dizzy
7 replies to this topic
#1 Scousemouse
Scousemouse
  • 358 posts
Posted 28 February 2017 - 07:06 PM
I was told by a "Mechanic" that my 91 Mini Mayfair had Electronic Ignition. When I recently fitted a new cap + rotor (pot luck on E/bay) I found this,Click on pic.
Clearly this is a POINTS dizzy,but is it a LUCAS 25D4  or a LUCAS 45D4 ??Attached File  20170224_143406 DIZZY.jpg   70.18K   30 downloads
When did Mini's go over to Electronic Dizzies??
Also I bought My Mayfair 1991 998cc,it came with a 3 clock (in line with driver) dash with Jap tacho,I've since
fitted a 3 clock Centre Binnicle and kept the tacho on the parcel shelf.
Was wondering if this is a MAYFAIR Sport, or the basic model??
Edited by Scousemouse, 01 March 2017 - 04:36 PM.
#2 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 28 February 2017 - 08:10 PM
I believe that's a 59d4 dizzy. The white "cam" to the left of the photo allows the contact faces of the points to slide as the advance/retard back plate moves. This was meant to clean the contact faces.
Cheers, Steve.
#3 Spider
  • 15,684 posts
Posted 28 February 2017 - 08:14 PM
That's a 54D4, more or less interchangable with a 45D4, mainly the drive dog that's different.
I'm not 100% certain, but I don't think the 998's ever got an electronic distributor from the factory.
Edited by Moke Spider, 28 February 2017 - 08:15 PM.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 01 March 2017 - 08:15 PM
If your mechanic actually looked at the distributor and said you have electronic, time to change your mechanic. I've not seen a 998 personally with a O.E electronic distributor only that age 1275s
#5 Scousemouse
Scousemouse
  • 358 posts
Posted 01 March 2017 - 09:22 PM
I don't think he even bothered because when I dropped the car off at his garage I said I'd like a service ...oil + filters,Plugs points,cap + rotor...needless to say car won't be seeing him anytime soon.
Still non the wiser on what DIZZY it is ...???
Edited by Scousemouse, 01 March 2017 - 09:24 PM.
#6 GraemeC
GraemeC
  • 7,467 posts
Posted 02 March 2017 - 07:13 AM
59D4
#7 whistler
whistler
  • 1,870 posts
Posted 02 March 2017 - 09:26 AM
There's a model number stamped on the side of the body.
#8 Ethel
  • 26,580 posts
Posted 02 March 2017 - 11:24 AM
59D4.
As said it's almost the same as a 45, most bits are interchangeable . The wiper points are intended to increase the service interval for the A+ engine, so they also have an A+ clamp.
There's also and electronic version, 59DM4 that was used on the Maestro and early Metty Turbos, but never on the Mini or other Metros - they had the 65DM4 if they were electronic.
