My 850 engine and gearbox is out of the car Checked to see if gears select.before putting back in car. I cannot get 3rd 4th and reverse.Is it possible that when it is back in car and running that it may be ok.thank you
850 Gearbox
Posted 01 March 2017 - 07:56 PM
Posted 01 March 2017 - 08:24 PM
Posted 01 March 2017 - 08:32 PM
thanks . I may have to get it checked.out.
Posted 01 March 2017 - 09:03 PM
Have you touched the gear selector at all? The bottom plate thing, if in the wrong way wont allow you to get all gears
Posted 01 March 2017 - 09:19 PM
no sure what the plate thing is.It has a magic wand gearstick if that makes any differance
Posted 01 March 2017 - 09:28 PM
sorry ignore me, was thinking of later boxes ![]()
Posted 01 March 2017 - 09:35 PM
thats ok will thanks anyway
Posted 01 March 2017 - 10:02 PM
When trying to select any of the gears while the engine is out, try slowing rotating both the diff output yokes, in the same direction, while trying to select the gear. Might need a helper. Once it goes in gear, you shouldn't be able to turn the yokes anymore, you'll only be able to spin them while in neutral.
