Door Seal
3 replies to this topic
#1 Steve220
Steve220
  • 5,062 posts
  • Local Club: BMC
Posted 08 March 2017 - 12:50 PM
Right peeps, talk to me about door seals!
My MPi is very much still at the collecting numerous parts stage. However, my door seals are split and tatty and I'd like to give myself every chance of holding the moisture out! MPi door seals are 2 parts per side, however earlier ones are single piece. In terms of profile and effectiveness, does my car really need the 2 part seals where water can congress at the join and cause rust?
Discuss.
#2 Midas Mk1
Midas Mk1
  • 5,786 posts
  • Local Club: S.U.N.M.C
Posted 08 March 2017 - 01:09 PM
My MPi ones leaked, swapped for the conventional type, problem solved. My 2p aha.
#3 Steve220
Steve220
  • 5,062 posts
  • Local Club: BMC
Posted 08 March 2017 - 01:19 PM
Any input is good input! Thanks for that. The only real different I see I that lower section of the MPi has a part that hooks over the carpet.
#4 RooBoonix
RooBoonix
  • 1,225 posts
Posted 08 March 2017 - 03:34 PM
I looked at the MPi 2 piece seals, but on my SPi I went for the one piece style. Feed it on really tight (push it right up in the corners) and make sure the drain slots line up with the drain holes in the door (takes a bit of guess work) and mine have been great
