How To Remove The Alternator Belt?
Best Answer xrocketengineer , 10 March 2017 - 01:13 AM
On page 332 of the PDF below tells you how to take the belt off. On page 331 tells you how to remove the alternator. Page 156 has the pump pulley removal. Page 160 has the coolant pump removal.
http://www.theminifo...attach_id=68239
Go to the full post
Posted 08 March 2017 - 06:41 PM
Posted 08 March 2017 - 07:37 PM
loosen of the mounting bolts and the arm and bolt. if it wont come take the alyernator off see y the belts to tight .
Posted 10 March 2017 - 01:13 AM Best Answer
Posted 10 March 2017 - 04:54 AM
You fitting a new belt? Cut it off.
Are you sure the tensioner is wound all the way to its full stop at the end of its play? I've never had them that tight in the past! Just wondering if the belt on there at the moment is the right one!
Posted 10 March 2017 - 03:43 PM
If the belt has never been changed and even if it has the threads on the tensioner mechanism may be rusty, preventing it from unscrewing the belt tensioner completely.
I have found that using a hex wrench in the alternator pulley end to turn it while encouraging the belt to move over has helped get a belt on or off.
Terry
