No Fuel To The Carb.
Posted 12 March 2017 - 05:12 PM
The car was lying up over winter and there's no fuel getting to the carb now when I turn it over. Just wondering how to go about troubleshooting this? Don't know if it's a mechanical or electric fuel pump.
Posted 12 March 2017 - 05:33 PM
Take the air filter off and put a couple of teaspoons of petrol down the carb inlet elbow. If it starts then the should be enough time for the pump (if it's a mechanical one) to pull fuel through. Another trick is to 'super choke' the carb by putting the palm of your hand over the carb inlet while you crank the engine, this will produce a vacuum and hopefully pull the fuel through.
Posted 13 March 2017 - 02:44 PM
Going to show just how much of a noob I am now and ask you to confirm that this is the elbow you're talking about? I'd rather ask a stupid question than do something stupid because I was too proud to ask
That's the one ;) if it runs then dies you know its a fuel issue
Posted 13 March 2017 - 09:43 PM
Took 2 tries but after that he ran no problem, thanks @panky
Edited by bob540, 13 March 2017 - 09:45 PM.
Posted 13 March 2017 - 10:00 PM
Glad it worked
