Just bought a 1990 mini mayfair with half built MG metro engine in it. apart from some obvious problems like engine steady bars and coolant hose problems i cannot get a spark out of the thing at all!! I'm not tho most technically minded about these things. i have attached a White and Pink wire to the '+' on the coil and two wires that came off the distributor to the '-'.
the white and pink wire has 12v when the ignition is turned on but when in the starting position drops to 10/9v. i connected 12v to the '+' directly so the voltage didn't drop but still cannot get a spark!! Can someone help please!!
