Should I Paint My Gearbox?
12 replies to this topic
#1 myminipickup
myminipickup
  • 152 posts
Posted 15 March 2017 - 03:55 PM
I am restoring a Mini pickup and currently rebuilding the gearbox. I was going to paint it BMC Green, but after removing all the old paint and cleaning it up, I'm not sure now if I should?! Any thoughts?
17342919_1691513514480549_15700628164370
#2 nicklouse
  • 18,696 posts
Posted 15 March 2017 - 03:56 PM
I would not.
#3 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 15 March 2017 - 04:43 PM
What did you clean it up with? It looks new.
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 15 March 2017 - 04:47 PM
Depends what you want in terms of originality (and then age of your pick up).
It does look very clean though - well done!
Edited by GraemeC, 18 March 2017 - 06:55 AM.
#5 tiger99
tiger99
  • 8,584 posts
Posted 15 March 2017 - 04:58 PM
I would, because after a few months on the road the bare metal looks horrible. Maybe polishing it like an alloy wheel might discourage dirt from sticking but you will still get superficial corrosion.
My first Mini came with the entire power plant painted the usual olive green. That may have been an Austin van because Morris followed a different policy (or was it the other way round?). The second was painted, but not olive green. Black I think. The third was bare, and soon looked the scruffiest. The engine block was yellow from new.
But it is down to personal preference. Neither choice is right or wrong unless authenticity is important to you. Whatever you do will have to cope with water, dirt and grime. If there was an easily cleanable finish it would be my preferred choice.
#6 Ethel
  • 26,073 posts
Posted 15 March 2017 - 05:09 PM
Second that, aluminum corrodes too especially that close to road salt. Silver wheel aerosol works great.
#7 myminipickup
myminipickup
  • 152 posts
Posted 15 March 2017 - 08:40 PM
Thanks for your help - perhaps I should just put a clear lacquer on it - something like this?
http://www.halfords....u-lacquer-500ml
#8 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 15 March 2017 - 10:21 PM
Recon that should be perfect as it states for polished metals.
#9 Rocket.
Rocket.
  • 1,441 posts
Posted 15 March 2017 - 10:55 PM
If you're not going to paint it I'd use ACF50 to protect it
Likely to get lacquer peel from stone chips
#10 myminipickup
myminipickup
  • 152 posts
Posted 15 March 2017 - 11:08 PM
yes - then it would look bad. Perhaps I should just leave it as is!
#11 Rocket.
Rocket.
  • 1,441 posts
Posted 15 March 2017 - 11:12 PM
I'm not sure what you use your car for but If it's not a daily driver it won't be to hard to keep it clean
#12 nicklouse
  • 18,696 posts
Posted 15 March 2017 - 11:38 PM
Once it has created its aluminium oxide layer it is protected from corrosion.
Painting only opens it up to more serious corrosion. Stone chips. Allow water in and ypthe chipped psint holds it there cresting worse corrosion.
Chipped psint looks poor. Chipped aluminium oxide is not noticed.
Once you have assembled and filled with oil there will be enough anti corrosion treatment on the surface to not worry.
#13 myminipickup
myminipickup
  • 152 posts
Posted 16 March 2017 - 01:25 PM
Thanks - I'll leave it as is...
