Rear Subframe Install
8 replies to this topic
#1 roy1964
roy1964
  • 58 posts
Posted 18 March 2017 - 07:30 AM
I tried refitting refurbished rear subframe back into mini this afternoon and have a little problem. The width of the subframe or to be more precise the width from outside surface of the trunnion bolt to the other seems to be wider than the gap between the guards where they fit. Do I need to really over tighten the bolts which would compress the rubber bushes or are there trunnion bolts that have a thinner head. I'm only talking a couple of millimetres either side.Attached File  IMG_0050.JPG   54.62K   37 downloads
Edited by roy1964, 18 March 2017 - 08:09 AM.
#2 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 18 March 2017 - 07:41 AM
Which way round have you got the top hat bushes on the trunnions? Photos would help
#3 Swift_General
Swift_General
  • 871 posts
Posted 18 March 2017 - 08:00 AM
I wouldn't over tighten, you'll risk damaging the thread and in any case it will have little effect as the amount by which the rubbers compress is preset as the pins can only be tightened until they bottom out on the subframe and then go no further (make sure this is happening otherwise you may not be tightening enough). Presumably you didn't have a problem before?
#4 tiger99
tiger99
  • 8,584 posts
Posted 18 March 2017 - 10:47 PM
What exactly has been refurbished and have there been any heelboard repairs?
#5 roy1964
roy1964
  • 58 posts
Posted 18 March 2017 - 11:18 PM
Problem sorted, found the old trunnion bolts( never throw anything away ) as you can see in the pic the head thickness is maybe 2mm thicker on the new ones, not much but just enough to give me the clearance. Off to find a friend with a lathe.
#6 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 19 March 2017 - 12:05 AM
Are they in too bad condition? I would clean up and reuse the originals personally
#7 Spider
  • 15,685 posts
Posted 19 March 2017 - 12:21 AM
From your first photo, it just simply didn't look tight enough.
The Trunnion Bolt has a should just where the thread finished. The have to be done up hard so that shoulder seats against the subframe. The rubbers will compress and bulge a bit.
#8 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 19 March 2017 - 06:11 AM
Putting the head thickness to one side, are the shank lengths exactly the same? As if so the head thickness is irrelevant.
Edited by Steve220, 19 March 2017 - 06:12 AM.
#9 roy1964
roy1964
  • 58 posts
Posted 20 March 2017 - 01:31 AM
Thankyou  moke spider, i was just being a little to soft on the tightening side, i put a little muscle into it and tighten them until bolt shaft stopped on the inside part of subframe. All holes now line up and i have a small amount of clearance between trunnion head and guards.
