Mpi Gearbox
Posted 19 March 2017 - 06:32 AM
What is a x pin diff?
If going to turbo or supercharge my engine in the future what do you recommend I do the gearbox to strengthen it if at all possible?
Any help or guidance would be helpful thanks
Posted 19 March 2017 - 07:58 AM
Hi Jase,
First off, if you want your gearbox rebuilt, I'd send it to Guessworks (he's a member on here also). A X pin (cross pin) diff has an extra set of satellite gears within the diff itself to add strength and give better power delivery, it's usually a common upgrade when people are increasing the engine's power.
The best thing you can do to your gearbox if increasing power is X pin diff and a fresh rebuild on the MPi box. If you don't mind the noise, then straight cut gears are your next bet.
The MPi is a bugger to turbo with the standard manifold due to the injector firing sequence. However, the Specialist component inlet system, coupled with a load of other supporting mods (low compression pistons, oil feed/drain, manifolds, GT17 turbo, intercooler, ECU etc), you should have an effective turbo set up.
Posted 19 March 2017 - 02:22 PM
Posted 19 March 2017 - 02:29 PM
Posted 19 March 2017 - 02:56 PM
What's the difference between 3.1 and 3.4 ratio?
I just would like the gearbox to be quick through the gears, handle the power output and be reliable
Posted 19 March 2017 - 03:01 PM
Edited by cian, 19 March 2017 - 03:03 PM.
Posted 19 March 2017 - 03:19 PM
Posted 20 March 2017 - 06:51 PM
drop stright cut gear are louder than gearbox s/c as the gears soak some of the nosie up i think.
