Brand New Minispares Cylinder Head Bolt Just Sheared! How Do I Get It Out?
50 replies to this topic
#1 mkw
mkw
  • 1,003 posts
Posted 19 March 2017 - 04:11 PM
Hi,
Just doing my new bolts up after engine rebuild and number 1 as per Haynes manual has just sheared off clean in the block. Not even got to 1st stage torque! Looks like some sub standard crap.
Anyway, I'll deal with that later. For the time being how do I get the sheared piece out? Help please!
#2 blacktulip
blacktulip
  • 6,224 posts
Posted 19 March 2017 - 04:14 PM
Are you talking about the head studs?
#3 nicklouse
  • 18,648 posts
Posted 19 March 2017 - 04:30 PM
strip it down and look at the remains.
Edited by nicklouse, 19 March 2017 - 04:30 PM.
#4 mkw
mkw
  • 1,003 posts
Posted 19 March 2017 - 04:32 PM
Yeah the stud, sorry. It's stripped, just a clean break, nothing to grab hold of.
#5 mpialan
mpialan
  • 117 posts
Posted 19 March 2017 - 04:40 PM
It sounds like your only solution is a screw removal kit. Essentially you drill a hole and drive a left hand screw into what is left of the stud. As the left hand screw tightens the stud is unscrewed. Good luck.
#6 MacGyver
MacGyver
  • 1,027 posts
Posted 19 March 2017 - 04:45 PM
Do you have a dremmel?
You might be able to cut a thin slot in it and use a flat screwdriver to take it out.
#7 mkw
mkw
  • 1,003 posts
Posted 19 March 2017 - 04:59 PM
I've tried the screw removal kit, it doesn't seem to touch it but I assume that's because they'll be ht bolts?
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 19 March 2017 - 05:05 PM
To be honest unless you have a decent extractor set you could end up compounding the issue. Is the stud flush with the head or proud?? if its proud then weld another bolt to the stub and then remove.
#9 Chris.Williams
Chris.Williams
  • 679 posts
Posted 19 March 2017 - 05:14 PM
These are brilliant
https://www.google.c...N1S5Ielc2Vy_dM:
#10 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 19 March 2017 - 05:58 PM
Is the engine in the car?
#11 Allrounder
Allrounder
  • 188 posts
  • Local Club: Hereford Motor Club
Posted 19 March 2017 - 05:59 PM
Protect the block face and get the welder out. Building up the weld so you can then grip it to undo what's left of the stud. If the threads were cleaned before the new studs when in then the remains won't be too hard to unscrew.
Good luck
#12 mkw
mkw
  • 1,003 posts
Posted 19 March 2017 - 06:20 PM
Nah, it's on the bench at the mo.
#13 mkw
mkw
  • 1,003 posts
Posted 19 March 2017 - 06:21 PM
Good luck
I thought about that but wasn't certain it would work. I've started drilling but can tell it's going to be a slow and steady type of job. Oh well, if in doubt I'll go back to the welding route.
#14 Connor_B
Connor_B
  • 33 posts
Posted 19 March 2017 - 06:24 PM
you could get some left hand twist drills and try those, never used any myself but heard they do the job.
Best of luck!
#15 panky
panky
  • 1,792 posts
Posted 19 March 2017 - 06:49 PM
Was it a head stud or a rocker pedestal one?
