Airbag Reset !
9 replies to this topic
#1 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 20 March 2017 - 12:47 AM
My wife vacuumed under the seat and now the airbag light has come on. I have had a look for loose cables and all seems fine but the light will not go out now. Please could someone help me to reset it on the dash.
#2 Steve220
Steve220
  • 5,059 posts
  • Local Club: BMC
Posted 20 March 2017 - 09:19 AM
It resets itself when the fault goes away. I'd check it all again! Which seat was it?
#3 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 20 March 2017 - 12:42 PM
Diver side it's on a 51 Bini.
#4 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 20 March 2017 - 02:49 PM
Probably the under seat connectors, common problem on loads of cars.
Being under the seat/on the floor the connectors get wet/damp, corrode or just get knocked around.
Clean the contacts up, check they connect properly, check no wires have been ripped out.
If all else fails lots of people chop the connectors off and solder the wires together.
Don't forget when working on the airbag system to disconnect the battery and leave it for 30 mins or so to ensure nothing fires off!!
#5 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 20 March 2017 - 06:41 PM
Don't I need to get the ECU fault reset, is that the only way to get rid of it. Ive tried all the above.
#6 ukcooper
ukcooper
  • 1,625 posts
Posted 20 March 2017 - 07:49 PM
best going to a bini forum i thinj  lots changed since the mini
#7 maximas
maximas
  • 108 posts
Posted 20 March 2017 - 08:48 PM
This exact same thing happened to mine,gave a lift to a friend,who adjusted the seat,pulled the cable under the seat by mistake,airbag light came on,reset would not work,neither would battery off for 30 mins,the cable goes straight to the battery in the boot,in the middle it has some kind of resister...took it to BMW.....new loom needed..£700... Sold it instead with the fault,just explained before it was sold to the buyer...
#8 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 20 March 2017 - 10:14 PM
Does this forum no longer cover Bini's anymore.
#9 r3k1355
r3k1355
  • 585 posts
Posted 22 March 2017 - 11:25 AM
The airbag system will use a separate controller unit so it's unlikely doing an ECU reset will help (because you'd be resetting the ECU not the airbag controller).
Usually for small things once you sort the issue the system resets on it's own, or disconnecting the battery for 30 minutes will do the same job.
Otherwise you need the dealer level software to talk to the airbag control unit.
Edited by r3k1355, 22 March 2017 - 11:25 AM.
#10 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 22 March 2017 - 12:34 PM
Ok thanks I will have a look at the weekend.
