Mini Mpi Rc40 Twin Box Exhaust System Too Loud (But New !)
15 replies to this topic
#1 eric.sen
eric.sen
  • 113 posts
Posted 27 March 2017 - 12:49 PM
I have a mini MPI with a new exhaust system :
It is the RC40 "Millennium" range :
- RC40 middle box in mild steel
- RC40 back box stainless steel  with large tail pipe silencer side exit
still the cat in place, but wanted to put a Maniflow LCB but don't know between the standard and and the "stage 2"
#2 Midas Mk1
Midas Mk1
  • 5,779 posts
  • Local Club: S.U.N.M.C
Posted 27 March 2017 - 12:53 PM
I have no idea how you think 3 boxes and 1.75 is loud aha
#3 imaparana
imaparana
  • 580 posts
Posted 27 March 2017 - 12:54 PM
just fitted the same thing to to my miss's car and didn't notice much different from standard with the cat in
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 27 March 2017 - 01:28 PM
i went for speacil compents lcb and mini mine front link pipe and it fitted like a glove cat went nice and tight to the floor
#5 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 27 March 2017 - 01:32 PM
Thats like the quietest exhaust combination ever :lol:
#6 Mervyn
Mervyn
  • 256 posts
Posted 27 March 2017 - 02:02 PM
It should quiet down a touch once filled with soot.
Regards
Merv
#7 leyland73
leyland73
  • 158 posts
Posted 27 March 2017 - 03:42 PM
Stainless exhaust will be a little more loud, but as Mervyn said it will quieten down with use. Rc40 best combination for a mini, lovely mellow sound to it.
Edited by leyland73, 27 March 2017 - 03:42 PM.
#8 eric.sen
eric.sen
  • 113 posts
Posted 27 March 2017 - 04:03 PM
Maybe a little more loud due to the LARGE BORE TAIL PIPE ?
Or Maybe due to the KN air filter I put in the box when I install the exhaust system ?
#9 eric.sen
eric.sen
  • 113 posts
Posted 27 March 2017 - 04:18 PM
Witch LCB is good for an MPI ?
Maniflow : Normal or Stage 2 ?
Specialist Components (but in stainless so more loud I think) ?
#10 Cooperman
  • 23,286 posts
Posted 27 March 2017 - 07:16 PM
Standard Maniflow LCB is excellent.
If too loud it might be the big-bore tail pipe. These are often called 'power-sapping noise-boosters'. They make more noise, but lose a few bhp because the exhaust gas slows locally before the end of the pipe and the gases don't exit at the correct speed, causing a local high-pressure area and a loss of power. The basic exhaust pipe, 1.75" dia, needs to be the same from the join to the LCB and the final exit point.
#11 mina08
mina08
  • 255 posts
Posted 28 March 2017 - 03:34 PM
are you sure its fitted properly (blowing) ?
#12 eric.sen
eric.sen
  • 113 posts
Posted 16 May 2017 - 04:29 PM
Do you test the 2 twin box exhaust systems ?
Maniflow and RC40 ?
#13 Cooperman
  • 23,286 posts
Posted 16 May 2017 - 04:51 PM
I have run both twin-box RC40 and twin box Maniflow systems on a 1275 'S' rally car. Rally cars have to meet strict noise levels and teh Maniflow was slightly noisier than the RC40, but it was better made, so stronger for competition.
In order to get best power the final exhaust pipe diameter must be the same as the rest of the pipe, or there will be a power loss caused by the over-size final exit. On a 1275 engine a 1.75" diameter pipe is best with a single 1.75" outlet pipe.
Set up properly both RC40 & Maniflow systems are reasonably quiet.
#14 eric.sen
eric.sen
  • 113 posts
Posted 17 May 2017 - 12:20 PM
Thanks for your help Cooperman :highfive:
#15 eric.sen
eric.sen
  • 113 posts
Posted 04 August 2017 - 12:17 PM
Some news....
I had a sump guard, took it off, it was doing resonance chamber,
now the car under acceleration is lot quiet.
:D
