Coolant Colour
9 replies to this topic
#1 camrocok
camrocok
  • 29 posts
Posted 28 March 2017 - 08:14 PM
I have searched for the answer to this question but not 100% sure I have the necessary information so apologies for asking again.
I have replaced the coolant with full flush three times in the last hundred miles.   The coolant immediately turns brown, presumably from rust in engine block.   Is this just something that I live with i.e. mucky coloured coolant or is there a magic potion I can add to cure the problem?
#2 minimans
minimans
  • 411 posts
Posted 28 March 2017 - 08:46 PM
If you want it really clean you will need to strip out the radiator and get it boiled/rodded out and then flush the block with a good descaler. and include the heater matrix in that as well. If it doesn't get hot leave it alone!
#3 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 28 March 2017 - 08:48 PM
Just run it, I do a flush whenever I change the water pump or if I need the engine out. I usually flush the full system With a garden hose, including the heater ( disconnect both heater hoses from engine and bottom hose, also disconnect the bottom hose from the water pump end, not the radiator end)
#4 minimans
minimans
  • 411 posts
Posted 28 March 2017 - 09:14 PM
I forgot to say remove the thermostat to flush the block.................
#5 Spider
  • 15,028 posts
Posted 28 March 2017 - 09:20 PM
It does sound like rust.
I would suggest draining all the coolant and flushing first with clean water several times.
Then do a (roughly) 50 / 50 mix of CLR and water (or even higher quantity of CLR) and running with that for at least a week. Flushing a few times and then going back to coolant.
https://www.amazon.c...r/dp/B00009EFEX
I have tried a number of commercial 'flushes' but I found none of these were any good.
#6 camrocok
camrocok
  • 29 posts
Posted 28 March 2017 - 09:21 PM
I have replaced the thermostat and not driven it a huge amount because still in state of restoration but it is not overheating
#7 richmondclassicsnorthwales
  • 942 posts
Posted 01 May 2017 - 06:06 AM
There is a fluid on the market, Evans Auto Cool Waterless coolant, it's expensive, but it eliminates problems associated with cast iron / aluminium / copper components. It is £65.00 for 5 litres
#8 Spider
  • 15,028 posts
Posted 01 May 2017 - 07:05 AM
I think this has come up on the forum previously.
This particular 'Coolant' is 100% Glycol. While it won't cause Corrosion or rusting in the System, however, it is a less than ideal Coolant.
I've read a few reports where classic car owners who have tried this and similar Coolants actually find the running temperature hotter than with water or mixed coolants.
#9 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 01 May 2017 - 09:16 AM
Seen this too, not good
#10 Dusky
Dusky
  • 5,322 posts
Posted 01 May 2017 - 11:26 AM
Must say I'm not a fan of waterless coolant either. After spending a fair few quid ( well , euro..;-) ) on it for our clubman, just to see the cooling was even worse than before. Also not allowed on most tracks anymore.
