12” Steel Wheel
11 replies to this topic
#1 1984mini25
1984mini25
  • 8,785 posts
Posted 29 March 2017 - 04:47 PM
I'm after one standard 12x4.5” steel wheel, but the type with the spacer as shown. Any condition as long as its straight and not bent, with or without tyre (condition of tyre not important) or just the rim on its own will do.
Edited by 1984mini25, 05 April 2017 - 10:11 PM.
#2 1984mini25
1984mini25
  • 8,785 posts
Posted 05 April 2017 - 10:11 PM
Bump
#3 Minitransition
Minitransition
  • 65 posts
Posted 06 April 2017 - 08:34 AM
Hi there (again),
I have got four unwanted 12" wheels but the spacer is not attached. Isn't it a separate item?
Happy to bring one to show you on Monday???
#4 1984mini25
1984mini25
  • 8,785 posts
Posted 06 April 2017 - 10:45 AM
I've already have a stack of 12" steelies, but only one is the type with the welded spacer as it's not a separate item.
There's two/three types of 12" mini wheel, ones with and without the spacer and ones with and without holes for the city hubcaps. The latter I'm not bothered about.
It's just my 25 had the spacer type from the factory and still has, but I'd like too also have a few spare. As I can't use a more common non spacered steel on the same axle as a spacered steel, as the spacer is about 1/4" and I'd end up with a crabbing mini.
#5 dodgy weedgie
dodgy weedgie
    Starting My Mini Up
  • 3 posts
  • Local Club: ESMOC
Posted 07 April 2017 - 06:51 AM
I have one there, that i know off. Would need posted.
07849 081713
Keith
#6 1984mini25
1984mini25
  • 8,785 posts
Posted 22 April 2017 - 09:00 PM
Bump, still on the lookout and could collect from Himley Hall in a few weeks time.
I've found a pair, but the seller won't post and there 90 miles away in Southampton. >_<
#7 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 22 April 2017 - 09:09 PM
Where are you? I have 2 steelers here 1 definitely with a spacer built in. I'm in essex
#8 1984mini25
1984mini25
  • 8,785 posts
Posted 22 April 2017 - 09:14 PM
Where are you? I have 2 steelers here 1 definitely with a spacer built in. I'm in Essex
I'm in Milton Keynes, I only need the one and preferably without the tyre, so i can refurbish it as a spare.
#9 bluemini1979
bluemini1979
  • 619 posts
Posted 24 April 2017 - 05:29 PM
I will get it out when I'm next at unit to double check the spacer is there and get a picture for you. I can take tyre off as well
#10 1984mini25
1984mini25
  • 8,785 posts
Posted 24 April 2017 - 06:08 PM
#11 1984mini25
1984mini25
  • 8,785 posts
Posted 04 May 2017 - 09:51 PM
Bump
#12 1984mini25
1984mini25
  • 8,785 posts
Posted 21 May 2017 - 07:51 PM
Bump, as the one I've 'bought' doesn't show signs of turning up.
