Keep Blowing Side Light Fuse
4 replies to this topic
#1 Phil terry
Phil terry
    Starting My Mini Up
  • 1 posts
Posted 31 March 2017 - 09:57 AM
Hiya, I have a 91 mini neon with a dim/dip relay and I keep blowing side light fuses.
I can't find a short in the wires, i've disconnected the dim/dip switch which made no effect, i've replaced the pink relay and the light switch. I'm stumped - any ideas??
Is it possible to bypass the pink box and the dim/dip relay as older minis don't have them?
Phil
#2 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 31 March 2017 - 12:22 PM
It is indeed possible, have a search around the forum using the search function
#3 hhhh
hhhh
  • 422 posts
Posted 31 March 2017 - 01:40 PM
A useful technique to find the cause of blowing fuses is to put a low wattage light bulb in place of the fuse, like a dome light, and then wiggle wires and whatever else until it flickers to locate the short.
#4 richmondclassicsnorthwales
  • 942 posts
Posted 01 May 2017 - 05:47 AM
I have had this issue, but with an MG Midget.
It was the last point i checked, which took 4 hours to locate. I started at the back, and moved forward and found it in the headlamp bowel.
On the inside of the headlamp bowl was a lip, and this was cutting into the sidelight positive wire, something as daft as that.
#5 hhhh
hhhh
  • 422 posts
Posted 01 May 2017 - 02:27 PM
Of course it was the last place you checked: when you find it you stop looking! O_O
