What are everyone's wheels centres or tue actual wheel centres from front to back on a zcars or a normal mini? I can't find any information about it online and mine are 30mm out on the front subframe. The rear cage is in square and all measures correct but it's a fibreglass shell and the holes for the towers are wrong I think. Can anyone help please.
Stephen
Wheel Centres
Stephenhasting
, Mar 31 2017 04:38 PM
1 reply to this topic
Posted 31 March 2017 - 04:38 PM
Posted 24 April 2017 - 09:46 AM
Dear Stephen,
The front wheels should be in the same position as with the original subframe. It is the rear axis that is usually sitting slightly further back. Originally the mini had a wheel base of 203cm and from my experience Zcars Minis are 205cm or more, depending on the rear arm rod ends adjustment.
Best wishes, Gonzo
