Fse Fuel Boost Regulator Fitting
11 replies to this topic
#1 DAC0800
DAC0800
  • 21 posts
Posted 02 April 2017 - 10:48 AM
Mini 1998 MPI
Hi I've got FSE Fuel boost regulator with no fitting instructions,I think I have nearly worked it out how to fit it but I'm stuck on fitting the fuel return pipe to the tank.At the end of the fuel rail there's a fitting that the return pipe comes from do I cut into that pipe and somehow block the end of the fuel rail and then connect the return to the FSE regulator or have I completely got it wrong and this makes no sense whatsoever
#2 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 02 April 2017 - 11:46 AM
There should be an adapter that replaced the current fuel pressure regulator. You install that then put a pipe from the adapter to the FSE. The return underneath the FSE then goes to the return pipe on the car. The sensor pipe that went to the top of the old fuel pressure regulator then goes to the top of the FSE. Hey presto! Then go get it set up. If you don't, you risk the car running lean, causing it to over heat and burn valves, or over fuel and cause bore wash. Either will destroy your engine.
#3 DAC0800
DAC0800
  • 21 posts
Posted 02 April 2017 - 12:39 PM
How do you join the pipe that's under the FSE to the fuel return to the tank ,The return pipe to the tank goes from the end of the fuel rail with a fitting do I cut it off
#4 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 02 April 2017 - 12:43 PM
Remove the fitting and you'll get a normal pipe end
Edited by Steve220, 02 April 2017 - 12:45 PM.
#5 DAC0800
DAC0800
  • 21 posts
Posted 02 April 2017 - 01:07 PM
i will try to attach a picture of fuel pipe end,This is the fitting ive got at the end of my fuel pipe i cant see how it comes off it looks like its a one piece unit and when i remove it whats going to stop the fuel shooting out of fuel rail
#6 DAC0800
DAC0800
  • 21 posts
Posted 02 April 2017 - 01:11 PM
i can see lower down the bulkhead the fuel pipe is like in your picture do i join it down there and screw a bolt into the end of the pipe that comes from end of fuel rail
#7 jamesmpi
jamesmpi
  • 1,940 posts
Posted 02 April 2017 - 02:06 PM
If you remove the two screw that hold that pipe attachment then the whole thing will pull away from the fuel rail. There is an o ring that sits in a groove on the inside of the rail that forms a tight seal. And yes some fuel will come out if there is fuel in the rail
#8 jamesmpi
jamesmpi
  • 1,940 posts
Posted 02 April 2017 - 02:19 PM
Does this help? Not written using a mini engine but the logic is the same
http://www.v8engines...rboostvalve.pdf
My kit also came with no instructions but the way I have it is the fuel feed hose (orange) stays untouched and connects to the RH side of the fuel rail (looking at the engine).
The fuel return hose (green connector on the bulkhead) is disconnected at fuel rail (LH end) and the bulkhead and is no longer required. Your kit should have a blanking plug for the end of the fuel rail. You now need to run and new pipe from the black port on the top left of the fuel rail (under the air filter) to the boost valve and another new pipe from the boost valve to the return fuel pipe on the bulkhead. Finally a vacuum pipe runs from the boost valve to manifold
Edited by jamesmpi, 02 April 2017 - 02:32 PM.
#9 DAC0800
DAC0800
  • 21 posts
Posted 02 April 2017 - 05:01 PM
Thanks for your help I had the feed and return colours mixed up I thought green was feed and red was return ,looks like I am still missing a blanking plate for the return feed at the end of fuel rail I will give them a ring tommorow
Thanks again Lee
#10 jamesmpi
jamesmpi
  • 1,940 posts
Posted 03 April 2017 - 05:51 AM
Thanks again Lee
Page 61 shows the fuel pipes
http://www.theminifo...attach_id=68239
#11 jamesquintin
jamesquintin
  • 1,017 posts
Posted 03 April 2017 - 01:38 PM
you shouldn't need a blanking plate at the end. The replacement valve on my Cooper S kit blocked off that end.
In my video somewhere
Q
#12 DAC0800
DAC0800
  • 21 posts
Posted 03 April 2017 - 04:55 PM
That is a brilliant video I'm in the process of fitting a stage 3 kit over the next year so now i can reference your video especially the alternator bracket which I didn't know about
Thanks Lee
