Timing Chain Cover A+ For Duplex Chain
4 replies to this topic
#1 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 02 April 2017 - 06:39 PM
Does anyone make one in tin that will clear the chain without a lot of modification?
I know DSN makes a lovely aluminum one .....but £165!
I was hoping someone knew of a tin one that would work.
I'm running a Vernier adjustable cam gear, that seems to be the main problem with mine.....
Edited by Magneto, 02 April 2017 - 06:48 PM.
#2 Compdoc
Compdoc
  • 612 posts
Posted 02 April 2017 - 06:54 PM
I was under the impression that the duplex chain sat closer to the block ,(That is why you need to change the bolts for countersunk screws) and will generally clear the existing cover.
Mini spares have a note on their timing chain covers, which says,"If fitting with duplex timing gears the metal indent by the oil seal will need tapping out to stop fouling on the chain. The plate on the inside should not foul but check for clearance.Always check for fan blade clearances".
#3 Spider
  • 15,201 posts
Posted 02 April 2017 - 07:06 PM
All the factory covers will clear duplex chain sets, including those with the Vernier Sprockets, though one or two of them do need small modification(s), the dimple as Compdoc has pointed out and some have an Oil Deflector that needs to be removed.
#4 Torgo
Torgo
  • 80 posts
Posted 02 April 2017 - 07:23 PM
Hi
As above, ive just fitted duplex timing and after cutting out the oil deflector and 2 mins with a hammer my original cover fitted fine.
#5 Magneto
Magneto
  • 889 posts
Posted 03 April 2017 - 03:29 AM
Well I went ahead and removed the oil deflector and pressed out the small dimple, the cover fits just fine now - but the oil deflector was definitely rubbing on the Vernier sprocket....thanks for the feedback and comments!
Edited by Magneto, 03 April 2017 - 03:29 AM.
