Mpi- Stage 3 Head And Med Roller Rocks
9 replies to this topic
#1 ukcooper
ukcooper
  • 1,625 posts
Posted 04 April 2017 - 03:59 PM
Having the head swopped now Finaly
Friend is doing the work he's messed around with minis for years and years.
bought stage 3 mini spares head (new)
Med roller rockers 1.5.1 15mm type (new)
and they dont fit or the rockers hold the valves open when adjusted to the max
So bought http://www.minispare...A1950.aspx|Back to image_zpsq5j5v5be.jpg
to solve it but just wondering should they need the spacer/shim??
Edited by ukcooper, 04 April 2017 - 04:06 PM.
#2 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 04 April 2017 - 06:56 PM
Messing around with spacers for mine ATM. 998 with a skimmed 12g295. I've noticed Mini Sport also do spacers, slightly thicker @  2mm. :tumble: I don't fancy stacking one on top of the other. Just want the one thick spacer. I don't think 2mm will be enough, as the Mini Spares ones are too thin @' 1.3mm.
Edited by Anthony30, 04 April 2017 - 06:58 PM.
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 04 April 2017 - 07:09 PM
https://www.minispor...r-shim-2mm.html
#4 ukcooper
ukcooper
  • 1,625 posts
will know Wednesday
Update Thursday as they did not turn up
Edited by ukcooper, 06 April 2017 - 03:57 PM.
#5 Midas Mk1
Midas Mk1
  • 5,781 posts
  • Local Club: S.U.N.M.C
Posted 04 April 2017 - 07:28 PM
MED do all different size shims, I needed to use them on my med 1.5's, though the head has been skimmed and the block decked.
#6 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 04 April 2017 - 07:54 PM
Can't seem to find the shims? :tumble:  :shy:
#7 jamesquintin
jamesquintin
  • 1,017 posts
Posted 05 April 2017 - 05:14 PM
​Yes you will need the shims, they came with my Cooper S kit (that had 1.5 rollers on them)
They go UNDER the pedastles ;)
​Q
#8 hhhh
hhhh
  • 422 posts
Posted 05 April 2017 - 06:06 PM
It's highly likely that you need to shorten your pushrods more than shim the rocker pillars to achieve proper geometry.
#9 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 05 April 2017 - 07:49 PM
Would the MED roller rockers actually make a difference on a road car? 998 12g295 maniflow inlet/full exhaust twin hs2 carbs k&n pancake filters standard 998 a+ camshaft. :shy:
#10 hhhh
hhhh
  • 422 posts
Posted 07 April 2017 - 09:09 PM
With such a low lift cam, I would expect an improvement using high lift rockers, especially with the well flowing 12G295.
