Engine Question
9 replies to this topic
#1 Chris.Williams
Chris.Williams
  • 679 posts
Posted 04 April 2017 - 08:12 PM
Morning all,
I'm considering buying a secondhand engine, it has an issue, but not one I can put my finger on.
Advice sort before the purchase please.
This is the blurb from the ad
"The engine pissed out a bit of coolant when ever I turned the car on but not a huge amount. It was suggested that it could be a crack in the head or head gasket. Had good even compression when taken out 6 months ago."
I thought maybe bypass hose, and once the thermostat opened the problem went away.....? Maybe maybe?
Or as he says, as simple as a headgasket.
Chris
#2 Spider
  • 15,684 posts
Posted 04 April 2017 - 08:27 PM
"Pissed out a bit of coolant"
From where?
If it's somewhere around the the head gasket line,, It could be a head gasket, it could also have a gouge in the deck of the block.
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 04 April 2017 - 08:39 PM
water pump gone and splashing the water about??
#4 Cooperman
  • 23,513 posts
Posted 04 April 2017 - 08:46 PM
There are many alternatives and if you are going to buy it as it is, you need to allow for a major re-build as a worst case scenario. Of course, it could be something very simple, but without more info it is impossible to say. Take no notice of what the vendor says!
#5 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 05 April 2017 - 04:07 AM
Sounds like radiator overflow as once the key is turned off the water heats up more, expands, and has to go somewhere, unless it has an expansion tank.
#6 Ethel
  • 26,580 posts
Posted 05 April 2017 - 07:58 AM
If it's doing it from cold the pressure to eject the water can only come from a compressing cylinder. Alternatively, could it be leaking slowly and collecting somewhere to be shaken off at start up? If it's out and a non runner the best you can do is a leak down test and/or be sure the price is acceptable for the worst case scenario.
#7 Chris.Williams
Chris.Williams
  • 679 posts
Posted 05 April 2017 - 01:33 PM
Well he wants $100 for it, your money £55.
I'm buying for the wife, she wants a project engine for a bit of fun.
Didn't want to buy a complete lemon, eg block flogged.
#8 tiger99
tiger99
  • 8,584 posts
Posted 07 April 2017 - 12:41 AM
At that price I would be inclined to take the risk.
#9 Spider
  • 15,684 posts
Posted 07 April 2017 - 01:13 AM
If it's a 1275 snap it up.
If it's a 998 - I'm sick of tripping over them, you're welcome to take one for 'free', but the cost will be that you have to take another.
#10 Chris.Williams
Chris.Williams
  • 679 posts
Posted 07 April 2017 - 09:27 PM
It's an 1100. I prefer a well setup 1100 over a 1275 to be fair......for an everyday driver.
