Ministox Suspension Issues
Posted 05 April 2017 - 12:59 PM
A friend has a ministox, brand new build at the start of the year, the issue we have is we need to lower the car 50mm whilst retaining standard suspension, any tips?
Posted 05 April 2017 - 01:08 PM
Just shorten the trumpets
Posted 05 April 2017 - 02:10 PM
Posted 05 April 2017 - 03:37 PM
One scrutineer(one of the ORCI board members) says we can, speak to another and they say no that isn't allowed....
http://www.hardierac...P=downloads&T=3
2017 Ministox
Then section 8
Edited by cal844, 05 April 2017 - 03:38 PM.
Posted 05 April 2017 - 03:39 PM
best bet is to post up the regs for a read.
as there will be wording elsewhere that will allow or disallow what you want.
rules are fun and must be read in full and not just in isolation.
Posted 05 April 2017 - 04:19 PM
Post now edited mate, with the instructions to get to the info
Posted 05 April 2017 - 04:28 PM
will have a read this evening.
Posted 05 April 2017 - 06:35 PM
The regs say nothing about lowering. They clearly do allow increasing the ride height by using washers between knuckle joints and trumpets. Why do you need to lower it?
Posted 05 April 2017 - 09:01 PM
Rulebook states that the minimum ride height(from ground to underside of gutter) to be 1170mm, we are at 1220mm with used cones(which has helped but we need it to be lower(ideally 1170-1200mm))
The car has the lift and torque, but will not turn(fitting the used suspension all round has helped(did have all new cones, changed to used)
Posted 05 April 2017 - 09:10 PM
AndRide height will be measured on the drivers side of the car, from
the ground to the underside of the roof gutter at the B pillar; it
must not be less than 1170mm at any time.
and finallySuspension components must remain standard. Suspension cones and ball sockets must be fitted unmodified and must be identical. (Adjustment of ride height may be achieved by adding washers).
All suspension parts must be mounted in the original position and must not be attached to any additional ironwork.
All cars must have suspension movement up and down. No lowering allowed.
Now I can think of ways you could lower it that would still comply with the rules. But you would only be lowering by about 30mm
Posted 06 April 2017 - 05:59 AM
First thing to note.
must not be less than 1170mm at any time.and finallySuspension components must remain standard. Suspension cones and ball sockets must be fitted unmodified and must be identical. (Adjustment of ride height may be achieved by adding washers).
Now I can think of ways you could lower it that would still comply with the rules. But you would only be lowering by about 30mmAll suspension parts must be mounted in the original position and must not be attached to any additional ironwork.
Perfect, how could this be achieved?
Posted 06 April 2017 - 08:59 AM
another part that is possibly open to discussion is
The floor pan must be retained and made good, where the steelwork is joined to the external steelwork the body or
floor pan must be made good.
what you want to consider is what the Mini Miglias do in regards to the mounting of the front subframe.
if you need more info PM me.
Posted 06 April 2017 - 09:02 AM
I never thought about that!
You have a pm
Edited by cal844, 06 April 2017 - 09:03 AM.
