Cellulose Painting
7 replies to this topic
#1 smithy3793
smithy3793
  • 259 posts
Posted 05 April 2017 - 01:18 PM
I have painted my car in tweed grey celly,
appeared to be a good finish until i started wet sanding it back.
it has tiny white specks where the paint hasn't taken correctly.
i was looking to flat it back and apply a few more coats of celly,
my question really is would i be able to apply directly to the celly once flatted back or would i have to re-apply the primer?
#2 pete l
pete l
  • 1,374 posts
Posted 05 April 2017 - 01:28 PM
Direct to celly no problem
#3 16vmini
16vmini
  • 370 posts
  • Local Club: 16v mini club
Posted 05 April 2017 - 03:54 PM
im no expert ( lol ) .. but i would worry what caused it not to stick in those spots , and will it again , obviously you can just try again, but you might find you have to go deeper to key surface
#4 Haygate
Haygate
  • 115 posts
Posted 05 April 2017 - 06:45 PM
Take a picture as it sounds like polish spots? If so you really need to take it right back then panel wipe it down and try again.
#5 miniseven61
miniseven61
  • 62 posts
Posted 05 April 2017 - 07:14 PM
If the paint is not adhered to the primer it could be moisture in the airline, have you drained your compressor lately, check the water trap is empty, wet flat 600 with soap and re-coat.
#6 smithy3793
smithy3793
  • 259 posts
Posted 06 April 2017 - 02:38 PM
Thanks for the comments,
I've got the easter week off work so I plan to flat it back and put on another 4-5 coats on i think.
hopefully the weather will be like it is this week!
I'm also going to drain my compressor and purchase a new air line too.
#7 absx2
absx2
  • 918 posts
Posted 06 April 2017 - 07:50 PM
You need a water trap about 4.5 + meters after the compressor for best results.
The distance allows the air to cool enough for water droplets to form so fitted directly to the tank is a waste of time.
#8 smithy3793
smithy3793
  • 259 posts
Posted 07 April 2017 - 09:19 AM
I have got a water trap directly before the hose attaches to my spray gun, hopefully this will be okay
