Engine Block Bore Size?
Posted 05 April 2017 - 02:08 PM
I just want to confirm the size of my engine block, it was purchased as a 1380.
I've measured the bores with digital callipers and it reads as 74mm / 2.9"
Would that be correct for a 1380?
Many thanks.
Posted 05 April 2017 - 02:09 PM
1380 would be a 73.5mm bore (on standard stroke).
What are the pistons stamped as?
Posted 05 April 2017 - 02:10 PM
close enough.
piston size is 73.5mm
Posted 05 April 2017 - 02:11 PM
Should be 73.5mm for 1380.
Posted 05 April 2017 - 03:00 PM
No pistons, it's a bare block that was being used to build up, but my retired Dad spent some winter evenings in his garage working on my 1380 MED so I'm going to stick this one and a standard 12G940 on eBay ;o)
Posted 05 April 2017 - 05:23 PM
Standard 12G940 might be a little wheezy. At least grind out the valve guide bosses and smooth it or something.
Posted 05 April 2017 - 07:09 PM
