1989 mini sky rose (originally)
2 pod dash, speed on the left fuel and temp on the right
Tried a new sender in boiling water
I have tested continuity from the sender plug, to the dash plug, all good lit my test light
I have grounded the sender end with the ignition on (engine not running) gauge did not move to the hot position
My fuel gauge works so i do not think its a voltage stabilizer issue as from what i have read i believe if that fails both temp and fuel do not work?
What is the next step? (other than getting a parts bin pod at the next show)
Thanks strangers ![]()
