Is it possible to make a standard gear stick have a shorter throw?
I know you can buy them cheap but I've extended and reshaped my gearstick because of where my seat is.
Thanks 😄
Making A Short Shifter
coopdog
, Apr 05 2017 07:03 PM
4 replies to this topic
Posted 05 April 2017 - 07:03 PM
Posted 06 April 2017 - 06:13 PM
They just raise the ball and socket to alter the lever rate. You could do the same if you're brave enough to cut n shut your selector casting with some ally section, or buy one and extend the bottom of your personalised stick
Posted 06 April 2017 - 10:19 PM
Welderup fam, buy a cheap one, use the collar that bolts to the linkage housing, extend the ball on your stick
the same amount as the one you bought, fit it, instant racecar
Posted 06 April 2017 - 10:21 PM
nstant racecar
Nah not racer. The gates are too close.
Posted 07 April 2017 - 12:26 AM
Thanks for the replies guys
