Aaaarrrrgggghhhh Help Urgent!
Best Answer greenmini1275 , 06 April 2017 - 01:52 PM
Mini is sorted and is actually running really nicely, perhaps it did need to blow through some gunk.
Cheers Guys.
Go to the full post
Posted 06 April 2017 - 08:36 AM
Oh and I was half asleep, my other car is a diesel and I was working on auto. Lol.
Posted 06 April 2017 - 08:40 AM
Drain tank, fuel lines and float chamber of carb. Take plugs out and wash in petrol, dry and replace. Put petrol in. Start.
Might run a little rough for a few miles.
Did you not struggle to get the Diesel nozzle in the filler neck?
Posted 06 April 2017 - 08:44 AM
Not at all.
Posted 06 April 2017 - 08:48 AM
A minis filler neck is massive compared to modern petrol cars.
What age is it?
Posted 06 April 2017 - 08:49 AM
Dad filled his mini up with diesel on the way home from L2B last year, then topped it off with 2 gallons of petrol when he realised what he'd done. I reckon the ratio was 1:3 petrol to diesel. He drove it all the way home (about 120 miles) on pretty much full choke as that was the only way it would run, and gradually drove it more and more til it ran right and seemed like all diesel was out of the system. Still going strong now, probably helped clean all the gunk out of the engine and head
Posted 06 April 2017 - 08:50 AM
Posted 06 April 2017 - 08:51 AM
You're lucky it's converted, the SPI system wouldn't like that at all
So no cat?
It might foul the plugs and be a bit smokey but it should be ok.
It's much worse the other way around, the diesel often lubricates the fuel pump and petrol doesn't. Petrol also burns a lot hotter
Posted 06 April 2017 - 09:00 AM
You would be surprised how common this is! used to do breakdown recovery for
a few years and miss fueling kept us busy remember one occasion draining £80s
with of diesel out of a petrol car after a bill for £250 it drove away no probs owner
was less happy!!!!
Posted 06 April 2017 - 09:01 AM
after doing the above get a can of easy start to help you get it fired up.
Posted 06 April 2017 - 09:16 AM
Posted 06 April 2017 - 10:12 AM
yeah as above get fuel through and get it started, main problem will be oiled up plugs, give them a clean and maybe warm them up with a blow torch or in the oven. get as much derv out as yu can and then brim the tank to dilute it as much as you can.
also once youve cleared it, it will be an idea to change the plugs.
Posted 06 April 2017 - 11:19 AM
I'll let you know, in a bit, need to have a bath and thoroughly scrub my teeth, phaaaaa.
Posted 06 April 2017 - 01:52 PM Best Answer
Cheers Guys.
Edited by greenmini1275, 06 April 2017 - 01:52 PM.
Posted 06 April 2017 - 06:40 PM
