Throttle And Choke Cable Removal
1 reply to this topic
#1 Mini Oll
Mini Oll
  • 65 posts
Posted 06 April 2017 - 05:36 PM
Hello,
I need to remove my carb and replace the jet as it seems to be leaking.
I have never removed a carb before and am struggling at the first hurdle. How do you remove the 2 cables?
I can't get any purchase on the throttle cable when trying to release the nut?
Any help very much appreciated.
#2 tiger99
tiger99
  • 8,584 posts
Posted 07 April 2017 - 12:48 AM
It would help to know which type of carburettor you have. On some, the throttle outer cable just sits in a bush on the mounting bracket, the inner passes through that and is clamped into a loose pin with a small bolt in the end. The pin should have a hex head so it can be held.
The choke cable outer is often clamped to its plate by a U or P clip and its inner again has a hex headed pin with small clamping screw.
