Renewing Brake Fluid Advice Please!
7 replies to this topic
#1 1314cc
1314cc
  • 303 posts
  • Local Club: tumbleweedminisbristol
Posted 07 April 2017 - 10:57 AM
Ok,wheel bearings, balljoints done. Now ready to replace calipers and hoses and new brake fluid. So can i just drain system dry then disconnect calipers and hoses? Then what's the best way to go about refilling the system?
#2 nicklouse
  • 18,998 posts
Posted 07 April 2017 - 10:59 AM
just bleed as per the order for you circuit.
how you do it depends on what kit you have.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 07 April 2017 - 11:03 AM
Dont forget though to make sure the new calipers are on the correct side. Brake nipples upper most. Might be teaching you to suck eggs but it happens a lot.
#4 1314cc
1314cc
  • 303 posts
Posted 07 April 2017 - 11:12 AM
Always welcome sound advice!
#5 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 07 April 2017 - 11:28 AM
If they are the wrong way up, you will never bleed the brakes.
#6 1314cc
1314cc
  • 303 posts
Posted 07 April 2017 - 04:39 PM
So by draining down the brake fluid, how easy is it to refill? Obviously there will be a lot of air in the system. Is just a case of bleed in sequence? Or should I expect it to be not so straight forward? I have borrowed an eezibleed kit
#7 Icey
Icey
  • 1,574 posts
Posted 07 April 2017 - 05:19 PM
There's no need to bleed it dry, you'll never get it all out anyway. Just put plenty through each corner and you won't go far wrong.
Edit:
One caveat - if contamination is your concern you'll want to be pulling the components apart anyway, that's the only reason I'd want to drain it all down just so I can clean and inspect. If it's otherwise good, just put plenty of fresh fluid through.
Edited by Icey, 07 April 2017 - 05:21 PM.
#8 Carlos W
Carlos W
  • 10,115 posts
Posted 07 April 2017 - 08:01 PM
Empty the master cylinder with a syringe
