I was going up the slip road and took the car out of 4th and went to go into 3rd and i couldn't find a gear i thought it was something to do with the gear selector, but when the car is off it goes into gear fine but when the engine is running you cannot put it into gear and the clutch is solid, it's something to do with the clutch master cylinder. When the cars running you can put it into reverse but the gears grinds, and the clutch fluid is fine and there's no leak. The mini is a 1999 Rover Mini MPI so it has a hydraulic clutch, I cannot think what it could be?
Clutch Isn't Working/car Not Going Into Gear
nick-searle
, Apr 07 2017 08:41 PM
No replies to this topic
This topic is locked
