Hi;
Think I have fixed it (will check again today and keep an eye on it).
I noticed some fluid on the floor and it turned out to be brake fluid!!
On inspection it looks to be coming out of the three way splitter where the front to rear enters it.
I tweaked the nut up a tad with a spanner and also the other two that go to the left and right wheels.
Is this a common issue caused through vibration and how should I prevent it?
My front to rear runs up and over the SubFrame (which is how it was before I did the resto, Should I run a new line underneath?
Took the Engine Enamel clean off but luckily didn't touch the Jotun Epoxy.
What's then best product for cleaning off brake fluid?
