clubman-fuse-block.jpg 34.55K
17 downloads
Few questions about updating current wiring, as you can see the current state.
So going by the wiring diagram here - http://www.minimania...Fs/wiring16.pdf
From 19 (fuse block)
Greens =
36 - windscreen wiper switch
25 - Flasher Unit
18 - Stop Lamp Switch
115 - Rear Window Demister Switch
37 - Windscreen Wiper Motor
I have measured the *Outside Diameter of the green wires 2.5mm
Browns Outside Diameter = 3mm
If i were to buy old type wiring from here - https://www.autoelec.../66/category/11
Then 2.6mm *OD (Outside Diameter) would be 8.75A
My questions are -
1) The rear window demister switch is a Amp draw of 10-20, depending on the element (according to this post http://www.theminifo...trical-circuit/ Is this correct and should I upgrade that circuit for higher amps.
2) Does anyone have wiring diagrams showing cable thickness on each circuit, if not this would be extremely handy for a lot of people (project for someone maybe).
3) I plan to go the Thin Wall cable route with the whole car, would it be overkill to fit 28/0.30, 2.0mm², 25.0A - cable OD 2.7mm in place of the green cables from the fuse block or would 32/0.20, 1.0mm², 16.5A - cable OD 2.0mm be enough.
4) I want the whole car to be 100% any advice on other circuits using Thin Wall cable from here
Many thanks in advance for reading and advice as always.
-G-
