Gearbox
11 replies to this topic
#1 ashleyread1
ashleyread1
  • 200 posts
  • Local Club: London and Surrey MOC
Posted 13 April 2017 - 08:03 AM
Hi,
So i had some knocking in my engine when running sounded like the idle gear was knocking around. but didn't seem to make the noise in fourth from what i could hear. however did stop with my foot on the clutch. i know have the gear box off and i think it might be a bearing in the gear box. i seem to have a bit of play on the bottom transfer gear i can almost move that end of the gear shaft.
Im guessing this means a new bearing for the main shaft that end of the box?
can anyone advise
#2 Spider
  • 15,684 posts
Posted 13 April 2017 - 09:01 AM
I think most of us would need photos to be able to offer specific advice.
However, from my experience, once anything one thing in the gearbox starts to give any trouble or get noisy etc, then while that can be fix, you can be sure that other items in the gearbox are not far behind. That being the case, I would advise that you consider a reconditioned gearbox.
#3 ashleyread1
ashleyread1
  • 200 posts
Posted 13 April 2017 - 09:16 AM
Thanks,
going to have someone look at the box today and give me a honest opinion on the whole thing including wear on gears. if this is that bad will take out my x pin and get a new box, do you know of where best i can get a relativity cheap recond box?
#4 Spider
  • 15,684 posts
Posted 13 April 2017 - 09:26 AM
Good to have someone look it over.
You could pick up a used box, but for all the work and money involved, I would suggest you think that over. The youngest gearbox around these days is at least 17 years old and all the miles that go with it.
Sorry, I'm an 'off-lander' and so I can't offer much in the way of advice where to look, other than ebay etc.
Why not try in the Wanted Section here on the forum?
#5 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 13 April 2017 - 09:33 AM
Thanks,
Try John at Guessworks. He's a member on here http://www.guess-works.com/ . If you look at his website you can see he offers fixed prices so you'll know the price before you start.
#6 Ethel
  • 26,580 posts
Posted 13 April 2017 - 12:24 PM
4th locks the 1st and 3rd motion shafts together for direct drive, so your initial diagnosis seems likely. It'd need stripping down to see if there's any wear to the shafts as well as failed bearings, I think Guessworks has a good stock of used parts, so even more likely to be a good contact if you need more than just bearings.
#7 ashleyread1
ashleyread1
  • 200 posts
Posted 13 April 2017 - 01:16 PM
got someone stripping the box for me today if it is badley worn other than the first motion bearing i think i will look to get a recon box from minispares, i see that they offer 250 for my old box? does this have to be all together also would i be able to take my diff as i have an x pin
#8 Ethel
  • 26,580 posts
Posted 13 April 2017 - 01:40 PM
You'd have to ask them, I would expect without a diff unless they offer final drive options, the diff housing will be required though as it's matched to the gearbox casting.
#9 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 13 April 2017 - 04:01 PM
John at Guessworks will rebuild you old box just replacing the worn parts and keeping your crosspin diff.
#10 ashleyread1
ashleyread1
  • 200 posts
Posted 13 April 2017 - 04:03 PM
my garage is going to replace the two bearings on the 1st motion shaft cheapest and best option for now i think.
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 13 April 2017 - 04:05 PM
That sounds like a good plan, its better value than a recon box if they're confident that's all it needs.
#12 ashleyread1
ashleyread1
  • 200 posts
Posted 18 April 2017 - 09:35 AM
Replaced the bearing at the weekend, all engine is back together with box and back in the car last night. shaft now has no movement so hopefully that stops the rattling will find out tonight
