Hammerite Kurust
5 replies to this topic
#1 Hen1275
Hen1275
  • 56 posts
Posted 14 April 2017 - 05:24 PM
After welding I've been putting hammerite kurust over the weld seams to minimise rust and I was wondering if I can put tiger seal or brushable sealant straight over the top of the kurust?
And regarding body filler, do I have to have a layer of primer over the kurust, then the filler on top? Or can filler be applied straight over the top of the kurust?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 14 April 2017 - 06:26 PM
In a word no. You need a primer so use Epoxy. Also as much as i used to use Kurust, Bilt Hamber Deox is by far a more superior product.
#3 Hen1275
Hen1275
  • 56 posts
Posted 14 April 2017 - 08:53 PM
So basically whenever using kurust/ bilt hamber deox always spray with epoxy primer afterwards? Then put sealer or filler over the top?
Thanks for the reply
#4 castafiore
castafiore
  • 116 posts
Posted 17 April 2017 - 05:56 PM
After welding, I prime, then seam seal, then prime again. I use Bilt Hamber Electrox primer, expensive but good. I use a cartridge seam sealer and initially used Tiger Seal. It's a good product but went hard in the tube after one session. After recommendations on the Mig forum, I started using this one from Toolstation:
http://www.toolstati...p85566?table=no
It will still go hard in the tube, but it's only £4.
I have tried the various recommended solutions - wrap in cling film, keep warm, stand in hot water before use etc.- and sometimes it works, and sometimes it doesn't. Try to time it so you have a lot of seam sealing to do in one go, rather than just a bit, then at least you will use most of the tube in one go.
#5 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 17 April 2017 - 05:59 PM
Yes in a word. Bare in mind to follow the instructions to the letter when using the Bilt Hamber Deox gel and make sure its bone dry afterwards.
#6 Hen1275
Hen1275
  • 56 posts
Posted 18 April 2017 - 04:46 PM
Okay thanks for the help. I'll order some Bilt Hanber Deox and get my self some Epoxy primer.
