Clubman Estate Side Window Seals
Posted 16 April 2017 - 03:49 PM
I've bought new clubman estate side(sliding) window seals
Part numbers:
14A7630
14A7631
14A7632
14A7633
One outer edge is 3-4 mm taller than the other side( on each of the numbers as above)
Does the taller side go the the outside of the car, or up against the vertical shoulder on the inside edge?
Posted 16 April 2017 - 06:00 PM
I believe the taller edge bears against the vertical shoulder on the inner edge of the window frame. The lower shorter edge would then allow water in the channel to drain out?
Someone who knows for definite will be along shortly hopefully!
Cheers, Steve.
Posted 16 April 2017 - 06:02 PM
Thanks for the input
Posted 21 April 2017 - 05:29 PM
Slot window into the bottom seal, then fit top seal onto windows and slide into place
Posted 21 April 2017 - 07:33 PM
Glad you got them all in!
Cheers, Steve.
Posted 21 April 2017 - 07:46 PM
Well done Cal,
Cheers, Steve.
Thanks mate, only took my dad and I from 11amtill 6 ish lol
Posted 29 April 2017 - 06:20 PM
The old runners were stuck solid and filled with moss. In the end I had to carve them away with a stanley knife and a used a makeshift prodding stick and literally peel away the old felt runners and remove the rusty frames. I slid the glass along to the front to remove the top screws, took the side frames out then carefully popped the top runner out until I was able to slide the old glass out.
Plenty of brews and sitting in the back thinking of what to do next was also involved.
Posted 29 April 2017 - 06:31 PM
I have just taken my rear windows out due to rotten running seals.
They're a pain
We cut the old rubber ones out.
The new minispares velvet items are a nightmare to fit
Posted 29 April 2017 - 07:03 PM
Do you have any pics of how they look after you have fitted them? I will keep you updated how the fitting goes 😆
Edited by Dandung86, 29 April 2017 - 07:03 PM.
Posted 29 April 2017 - 07:18 PM
We fitted ours without the picture frame external finishers fitted, much easierI have got them ready to fit, I got all 4 sides bit need to prep the metal frame first and remove bita of rust etc. By the looks of it they have been leaking for a while.
Top tip:
Cut and fit the bottom and vertical seals, then you need to place the widows into the middle of the lower seal, then fit top seal to windows and slide into place
Give me 10 mins, I will add pics :)
Edited by cal844, 29 April 2017 - 07:19 PM.
Posted 29 April 2017 - 07:54 PM
Posted 29 April 2017 - 08:12 PM
That's great, thanks for the tip. I will keep you posted how it goes. Yours looks nice so far.
Just needs the fuel tank fitted then fit the seats and fire it up :)
If you need any tips just post here
Posted 29 April 2017 - 08:14 PM
I've been putting this job off for a long time. This thread is giving me some inspiration.
Posted 29 April 2017 - 08:18 PM
We used the part numbers listed in the first post, the seals need drilled and screwed to allow the windows to fit
