Copper S 2000 W Reg Indicator Fault
3 replies to this topic
#1 smile u drive a mini :-)
    Starting My Mini Up
  • 3 posts
Posted 16 April 2017 - 04:25 PM
If I put my right indicator on it blows 10amp fuseC4 on fuse board. Left indicator fine, radio fine and clock fine hazard blows it as well. If I set the alarm off all indicator lights work fine any ideas?
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 16 April 2017 - 09:29 PM
Check the front wires(behind grille) for chafing/ burst insulation then I'd clean all the connections up(earth connection at bulkhead triangulation too!) Then try, I'd suspect an issue with the stalk after that as you say it works with the alarm and hazards
#3 Icey
Icey
  • 1,574 posts
Posted 16 April 2017 - 09:45 PM
If using the right indicator and using the hazard switch both blow the fuse but the alarm (which flashes the right-hand lights) doesn't, it's not going to be anything on the ends of the loom, it's going to be behind the dash. I'd be looking at the hazard switch itself, it's the only place those circuits come together.
#4 smile u drive a mini :-)
    Starting My Mini Up
  • 3 posts
Posted 18 April 2017 - 01:22 PM
Cheers have a look
