I'm genuinely interested in what others may have to say, but as I se it, that end of the Primary Gear, with the actual gear on it, is loaded more than the other end, so it does need a bit more support (and to put it in very simple terms, a harder bush). The factory did this with a steel backed bush.
The floating bush to my way of thinking and having examined this in some detail is offered as a cheap and lazy solution to a problem that is a bit more complex than what these bushes can do.
Probably not a proper answer, but the material used in them is nothing new, been around since long before the Mini, and one that the factory may have looked at I'm sure, yet they chose a few times when the Primary Gear was reviewed not to go this way.
<EDIT: Another possible reason for these bushes coming in to being is that in the UK, there was no factory information on the correct replacement procedure for the originals, so goodness knows what inadvertent bodges this lead to and so the originals - unfairly in my books - got a bad reputation. The correct procedure was included in the Australian Workshop Manuals though. The originals were very good and didn't damage the crankshafts. I've replace many over the years using the factory advice and had good life from them.>
<2nd Edit: The original bushes were 40 HB in hardness, while the floating bushes has a measured hardness of 110 HB and the crankshafts are 180 - 230 HB. No wonder they eat cranks!
The Back (Top Hat) Bronze Bushes I note are extruded and while haven't yet tested them for hardness, would be work hardened from the extrusion process, so even harder again than the floating bushes. >
Edited by Moke Spider, 17 April 2017 - 09:12 AM.
