Fuse Keeps Popping And Indicator Stopped Working
5 replies to this topic
#1 fat_fender
fat_fender
    Just On Tickover
  • 7 posts
Posted 18 April 2017 - 08:50 AM
My indicators stopped working so I checked the fuse and the top fuse had popped so I replaced it, but it keeps popping, I can drive around for awhile without an issue but then they stop working, I have checked the wiring around the steering column and all seems fine, the hazard switch doesn't seem to light up I googled they are connected to the indicators...
Where should I start looking at the wiring before the hazard switch or after?
Any help would be great thanks
Car is a 1979 Clubman.
#2 CMXCVIII
CMXCVIII
  • 374 posts
Posted 18 April 2017 - 09:43 AM
Does your car have reversing lights? I think so.
Check the clearance between the bottom of the gearlever and the exhaust pipe.  If they touch, the reverse light switch can short and blow the fuse.
Jon
#3 fat_fender
fat_fender
    Just On Tickover
  • 7 posts
Posted 18 April 2017 - 10:04 AM
Jon
Thanks for the quick reply, that may indeed be the problem, as they were working fine till I had to reverse out of my drive way.
#4 fat_fender
fat_fender
    Just On Tickover
  • 7 posts
Posted 19 April 2017 - 04:05 AM
Had a look today and yes looks like the plastic from the connector had worn away and was touching the exhaust pipe making it pop the fuse.
Many thanks for the help.
#5 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 19 April 2017 - 09:38 AM
Just disconnect the wiring, you don't need reverse lights
#6 CMXCVIII
CMXCVIII
  • 374 posts
Posted 19 April 2017 - 09:43 AM
Good! :highfive:
That's one I found out the hard way! I don't know if New Zealand roads even have many bumps like inner London speed humps, but if they do, you'll know where to look next time the fuse blows.
