Hi.
So I gave up on my own loom and bought a new one.
I'm spending the day labelling it all up ready to hopefully easily fit tmrw.
When the Haynes manual says LH indicator I assume and against my logic that it means LH as you look at the engine from the front of the car?
I would have assumed LH is passenger side and RH drivers, but if so then my loom is incorrect as I have green white LH indicator next to the brake fluid reservoir cap and light wiring hat runs down the drivers inner wing. And green red RH indicator next to the radiator.
Second question is I have lots of connectors on this loom that look like open bullet connectors. Should the wiring I have left have a connector that fits inside these? or is this the way a new loom would come ready for me to join wires together?
Car is a 93spi so the wiring is similar to most older models.
Wiring Loom Questions
idlethumbs
, Apr 18 2017 01:39 PM
No replies to this topic
